Tree-Farmer
I have a Craftsman YT3000 mower, it’s been fairly dependable.
Now it starts, runs for a second, then shuts off. I describe it that way, because it's actually starting, runs, fires a few times.. This is not the standard problem that a mower won’t start. It does start, but immediately dies. When this first started happening, it would run for 10 seconds or 30 seconds before dying, so I was able to drive it back to the shed.
What do you think this could be? What could I check?
I thought maybe the auto shutoff was shutting off gas. I took it out, put 12V on it and the mechanism moves, so that’s working.
But I guess it could still be that, maybe it’s not getting the 12 volts. I tried to measure it, I think it’s getting the 12 V, but only when you start it, so that’s hard to measure.
I don’t think it’s the seat switch, because it wouldn’t start at all, if that was bad, right?
I took out the spark plug, checked it, it is sparking.
I put in a new fuel filter, but that didn't make any difference.
I even tried it without the gas cap, but same thing.
When I remove the fuel line, gas does run out. But I haven’t taken off the carburetor yet.
What do you think could cause the motor to immediately turn off?
