Must be Monday
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/eapwj
So, it broke through but held on the frame, and they are putting cribbing under it to raise it back up? Not quite done yet need a jack to finish the cribbing? Otherwise I
cant make the pic make sense.
Im also having problems with the picture, but I see the chimney is missing (broken?) so I think it must have fallen all the way.
I'll bet that railroad jacks were more common than cameras. After a day and a half the photographer finally got there so they took a break for a photo.
Why a railroad jack. There were plenty of screw jacks back then. they would lift as much as you could pulll with the bar handle they had. We had one we used for jacking up barn timbers to replace one if it broke. Also would use it to level house timbers and then block up to that point. I bought one with holes for a bar at 1/4 turns so could have 2 guys pushing or pulling.
(quoted from post at 05:49:56 04/25/22) Why a railroad jack. There were plenty of screw jacks back then. they would lift as much as you could pulll with the bar handle they had. We had one we used for jacking up barn timbers to replace one if it broke. Also would use it to level house timbers and then block up to that point. I bought one with holes for a bar at 1/4 turns so could have 2 guys pushing or pulling.
One nice thing about the railroad jacks is the bar works on a vertical plane instead of horizontal so you work standing up instead of lying down or crouching. I have use both railroad jacks and screws plenty.
''metric'' I think is slang for ''..it doesnt look like an American steamer.''?
I agree, with those huge front wheels, distinctive cast spokes all around and that elaborate steam chest, I'd GUESS it is an Averling Porter from the U.K.
(quoted from post at 20:59:10 04/25/22) Guess I need to show my ignorance here. What is a railroad jack?
Railroad jacks are very big and heavy. Mine stands around 20 inches high, and the upper cylindrical part is about eight inches in diameter. They can raise something sitting on top, or sitting on the "toe" which sticks out about five inches on one side near the bottom of the outer/upper part. The crew would dig a hole next to the rail, and slide it in with the toe under the rail to raise it up. They could then push ballast under the ties to raise a low area. The operating shaft comes out the side opposite the "toe" so that the operating bar slips into a socket and the bar is operated back and forth instead of around and around like a screw jack. Mine weighs maybe sixty lbs.
(quoted from post at 14:49:43 04/25/22) Those workers dont look metric they look Gold Rush era.
Wonder where that pic was taken.
Yeah,
They can't be British, they don't have a tie on.
