My JD tractor temperature
37 chief
Mowing some bottom land today it was probably pushing 90, or more out. My JD was running hotter than normal, probably 200+ degrees on the gage. It wasn't boiling, so I wasn't real worried. I just kept my screens clean. My question is just because it's hotter out why is my tractor heating more than normal?
Seams to me it would have to be 200 degrees out, to effect the tractor temperature. Going back and forth looking at the front hood and muffler all morning, and watching frogs getting run over. My mind starts to come up with crazy things. Tractor temperature is one of them today. Stan
(quoted from post at 18:46:56 10/01/21) Mowing some bottom land today it was probably pushing 90, or more out. My JD was running hotter than normal, probably 200+ degrees on the gage. It wasn't boiling, so I wasn't real worried. I just kept my screens clean. My question is just because it's hotter out why is my tractor heating more than normal?
The less the difference between the engine temp and the ambient temp the less heat will transfer from the radiator fins to the air, so the engine temp will be higher.
Thermo-syphon system or does it have a pressure system? Hot air circulating through the radiator no matter what type you have for cooling system is not as effective as cooler air. An old mechanic told me many years ago that I-H didn't install a heat guage on early tractors with thermo-syphon systems because the engineers didn't want you to know how hot the motor was running.
Pretty much a normal situation , 90 degree air is not going to cool the engine efficiently compared to 60 degree weather. Same thing with my truck pulling a trailer in 90 degrees. It will run hotter than on a cool day.
But there is a difference in that 2 thermostatically controlled, electric fans pull air through the radiator, condenser coil, and tranny fluid cooler when the engine requires their assistance, vs a belt driven fan.
Besides washing the fins mentioned, check your fan belt. It needs to be tightened to spec to pull the required air.
I was having that problem with my Chinese tractor. It has a good guard, screen in front of radiator but had puked some coolant at times. I found the radiator still had a lot of dust on fins. Hard to get cleaned properly. Now clean, no problem.
