Hello. I have a New Holland TT60 tractor that as it always goes ran fine the last time I used it but been sitting out in the weather for about 1 month and now it won't crank. I've found 4 safety switches. Out of the 4 switches 3 are 2 pin connectors and 1 is 4 pin. For testing reasons I have unpluged all the safety switches and used a jumper wire to bypass each switch trying to rule out if safety switch is causing the no crank issue I have. The only switch I haven't ruled out yet has 4 pins and not sure how to jump this 4 pin plug. Can this switch be unpluged and jumper wire used to rule this switch out?
Thank you
Scotty
Thank you
Scotty
