jtaylor-HT
So I have had my YM1900 for about 2 years and have since: rebuilt engine with new sleeves, pistons, bearings, valves and painted tractor along with other modern features. Hoye Tractor had all of the parts and I could not be happier.
However, I noticed last summer the tractor had a hard time picking up my bush hog and picked it up slowly. Also I could lift a light attachement all the way up, then lower it half way and try to raise up again and it would not. I could then lower it and then pick it up slowly. Well orings do go bad after 35+ years. So I conducted the leak down test as outlined on Hoyetractors website. So I ordered the parts to replace the piston oring and all other orings that are part of the lift. Everything went well and looked good. Everything was cleaned and checked out okay.
So after I got everything back together I was excited to try to push some of the 40.5 inches of snow we got 2 weeks ago and have fun using my yanmar. The tractor now even struggles to pick up the blade to full height. So it has to be the pump as well. I know the pumps are expensive, but I wanted a quality pump that would last and lift. I did not even look at the junk out there and bought the one from Hoye.
During removal of the old pump I did not notice anything out of the normal. While waiting on my new pump, I drained the hydraulic fluid, cleaned the screen filter (only 20 hrs on it). I pump everything back together and waited for the pump. The pump have ARRIVED. I installed the new pump taking special care to keep it clean. Before starting the tractor I opened the hydraulic fill port as to avoid the possible of a vacuum and starve the pump of oiil for those first very seconds. Tractor starts and I hear a little chatter coming from the pump. I worked the lift with no load a few time to purge air. The pump still chatters especially when the lift is all the way down. I can move the lift just as it starts to move and the chatter stops. The pump does not chatter while lifting but will during lifting. I did not want to run it anymore, so I called Hoye to advise me. The fellow said that it can be expected get some chatter, because the pumps are tight and let the new parts wear in a little. Hoye has great people but just like to see if others has experienced this. Would it be advisable to remove pump and turn the shaft/coupler 180 degrees,run it a little at slow speed and take back apart and inspect, or.........or is this an expecte noise until break in of new pump.....
BTW those pumps from hoye are FAST and Responsive!
Thanks in advance for your input
