New Idea 323 trash roll bearing replacement
Dusthill88
Hi Im new to posting on forums but Im trying to figure out how the trash rolls come apart on my 323 new idea picker its the bottom roll right side bearing that I need to replace. Thanks for any help! Im trying to figure out if the hub on the right comes off of the shaft or not
When you say right side, are you facing the tractor or the wagon elevator? If it's that bearing behind the slip clutch hub on the right side facing the elevator, it's a nasty job to change it. The roll pins holding the trash roller to the shaft need to be knocked out and the shaft has to be pushed through the roller to get it out. I did one on a 2-row that had rusted together, which required using torches to heat the roller cherry red to get the shaft loose.
