New pistons
oHIo Jim
Bought a rebuild kit for 52 farmall super m, it came with stepped pistons, originals are flat top, is this going to lower compression ? Should I be looking for some flat tops ?
not sure what u mean by stepped. but if anything they must be a higher compression piston, which is good. picture?
The stepped parts of the piston stick up into the combustion chamber. they are designed to not hit the valves, so no worry there. It should make maybe 5 horse power more. Regular gasolinr will be fine. Jim
Jim welcome to YT! Unless your new step pistons have a substantial dish portion opposite of the step that would be lower than the top of the cylinder deck ...flat surface head gasket sets on...when the piston is at top dead center they will raise the compression ratio. I will link a video by Hot Rod magazine staffer Dave Freiburger, who was at one point lead editor of the magazine, explaining compression ratio. If you dot have time to devote 13 some minutes to this watch it up to 3 minutes then skip to 6 and watch about another minute. It should cover any questions you have on the topic. I sure hope that any one in the US that is about to change the pistons in an engine knows about Hot Rod. If not I have lost part of my faith in humanity.
Compression ratio explained
I would not install flat pistons in a gasser, the higher compression is free HP and fuel economy. You might have to back your timing off a little from stock.
Fast I don’t know if you ever listen to pod cast but there is a guy that goes by Hot Rod Farmer. He is a sweet corn farmer in New Jersey. In his podcasts series he does a couple shows on ..How engines make power.. As far as explaining theory correctly and in understandable terms he is very good, and he has engineering degrees to backup his knowledge if you even care about that. There is a bit of ..fluff.. in his shows a lot of which has to do with the sincere purpose of his show to essentially help farmers maintain their equipment as well as possible to help them be as profitable as possible. By no connection it so happens that when I first stumbled across his pad casts a couple months ago I found out one of his careers was being a technical writer, Hot Rod magazine was one of the publications he wrote for. I’m not sure but the link may require you to use a podcast app. If it won’t work search Farm Machinery Digest then click the three line in the black bar above ..Learning Series.. it will give an option to click podcasts there.
HR Farmer podcasts on engine power
