O/T spring is here
Got a question on subsoiling. Plowed the garden plots in the fall(OF 2009 w/a twin 14" plow. My question is "Would it benifit me to sub-soil now w/ a sub-soiler or would it be better to spread the compost and till w/ a 6ft. rotavator and go ahead and plant and not worry about the sub-soling until this fall (2010)????
We're running a truck garden on a small operation and hoping to make money on a small road/side busuines. Any repliesappreciated Thanks
Usually sub-soiling is done instead of plowing. Go ahead and spread your compost and work it in with your vator. Even that don't do to deep. Then in fall you can plow or sub-soil to your choosing.
Subsoiling works best when the ground is dry so it lifts & shatters, instead of just dragging the shanks through the wet sticky ground.
Do it in the fall, just use your tiller for now & do it like normal.
if you work wet clay soil you will get a lot of bricks in your garden. Corn does not germinate well until the soil reaches 60 degrees.Dont be in a hurry ,stressed plants never do well.
