Got JD 60 back from engine overhaul and belt pulley slings a little milky oil after running awhile. Then the clutch broke. I m no mechanic but enjoy tinkering so took clutch apart and found the fork broke and the shield behind pulley was filthy with a clogged drain hole. Also found the pulley bearing was missing and obviously the old sharecropper who worked for my uncle had packed it with oil soaked paper in an attempt to remedy situation. Got all parts ordered and cleaned up and ready to install. The first reduction gear has milky gear oil on it which is obviously contaminated with water. The engine oil looks fine. So if the clutch mechanism is lubricated with engine oil which is supposed to drain back into the crankcase through the now cleaned out drain hole, why did I find milky gear oil in it when I took it apart? I don t understand what keeps the transmission oil on the first reduction gear separate from the engine oil behind the belt pulley. Obviously I m going to drain, flush and refill the transmission, but I m afraid something inside the first reduction gear housing may not be right even though the tractor runs and drives fine. There are no 2 cylinder guys in my area. Sadly most are dead. The old guy who rebuilt it did his best but the clogged drain hole makes me doubt him. And yes I have the IT shop, parts and owners manual. Thanks foe any help!
