On my '46 H I frequently (frequently enough to be annoying, but not every time I run the tractor) have to pull the same two spark plugs due to oil fouling. I get a nice gunky build-up on the ends of the plugs, effectively filling the gap. The odd thing is, I don't have the common trail of blue smoke that often accompanies the burning of oil. I also regularly am (of course) adding oil (I joke that the H has 'self-changing' oil due the frequency that I have to top it up. The problem persists even after I removed and cleaned the oil breather and replaced the oil breather "filter" inside the tube assembly (and checked to make sure I got good airflow in there after changing the goofy filter material).
So I am wondering if others have had the same symptoms and what was the cause? Valve guides or piston rings?
Has anyone had luck in adding stem seals in an H? I see seals advertised but I have a distillate head H and the notes (on the Steiner site anyways) say the seals fit: "'some' of the following models using gas cylinder head casting #'s 8043D, 8043DB, 8043DC." Are distillate valve stems too short to fit the seals? Or do distillate valves have thinner stem diameter? Anyone add modern o-ring type seals? Do seals even matter?!
I am of course going to do a leak-down test, but I'm at work the next 3 days and figured I'd pop into the Forum because my overactive-brain is impatient to get out there and get some info. The last time I did a leak-down test it turned out that one of my exhaust valves lost it's keeper clip and the valve had dropped down...rendering that cylinder in-op (no damage done, fixed and working again)...and once I discovered that I then got sidetracked with the repair and moved on to other things. But the oiled plugs and oil consumption remain a problem to be solved. These days the oil consumption bothers me more because oil is getting noticeably more expensive.
