rusty6
- Location
- East central Sask.
(quoted from post at 22:54:20 10/18/20) I did a video tour of great uncle Alf's log barn a few days ago. Found stuff I forgot I had. Vertical log construction from poplar trees and it has stood over 113 years. Not sure if I posted a link to the first part but here is part two.
Log Barn
The house I live in, 1920 vintage, is lathe and plaster on the inside walls but the lathes are thin, flat sided pieces. Not willows. And it is real plaster with a smooth and flat finish.(quoted from post at 01:19:50 10/19/20) Our house, which was built in the 1600's had walls and ceilings like that, they are called "lathe and plaster" over here. Made with willow strips and plaster packed between and allowed to dry.
Quefan, thanks for the link to the log hewing video. Very informative and it occurs to me that I have all those tools necessary to do my own log construction. Including acres of big poplar trees.(quoted from post at 03:44:56 10/19/20) Hi Rusty6,
The square end iron bar with points that you were not sure of, is a "log iron" used to hold logs in position for hewing with broad axe.
