Old school Prestone no more?
MarkB_MI
Location
Motown USA
The other day I was in the auto parts store and noticed that the "old" Prestone antifreeze was no longer on the shelf. You know, the green stuff with the famous "silicone/silicate" additives. The closest thing they have is <a href="https://prestone.com/products?detail=AF2000">Prestone "All Vehicles"</a>. When I got home, I checked the jug of Prestone I bought last year for my tractor and was surprised to find it is also the "All Vehicles" Prestone, NOT the old stuff. This antifreeze is pale green in color, not nearly as dark as the old Prestone. Since it says it's compatible with "all" other antifreeze and doesn't say anything about silicones or silicates, I have to assume it uses organic additive technology (OAT). ("Organic" means "carbon-based", not that it's somehow good for the environment.)
There's no mention of the old Prestone on their website, either, so it sounds like they've discontinued it. They do list something called <a href="https://prestone.com/products?detail=AF3200">Prime by Prestone "Conventional Green"</a>, which seems like it must be similar to the old Prestone. I have no idea where you would buy it, if you wanted to.
So, my point is, it seems the concerns about mixing new OAT antifreeze with the old stuff are now moot, since the old NOAT antifreeze is for practical purposes no longer available. Unless you drain and flush out your old green antifreeze when you add coolant, you WILL BE MIXING ANTIFREEZE TYPES!
I got stuff that takes green and some take pink. Picked up a new F350 Super Duty yesterday that's got yellow in it.
I suppose it was inevitable, Mark.
Aside from my car which has the modern stuff, I maintain 7 (8?) liquid cooled engines, all of which have the old type "permanent" antifreeze and most of which were recently changed.
If younger, I would stock up on conventional permanent antifreeze to avoid the need to "change over" (conjurs up memories of the R12 (?) debacle, wherein I did stock up) but at my age, I expect that I can ride it out.
Dean
A lot of people just dumped out old antifreeze out on the ground to dispose of it. The old antifreeze was tasty to animals and very poisonous. All they did was add something to it to make it taste bad.
My local Rural King stores have pallets of these in stock. Its not quite as dark green as the old stuff but pretty close
I haven’t checked lately, but I suspect John Deere still sells Cool Guard II, some of the best “green” stuff there is.
(quoted from post at 23:04:04 09/03/20) My local Rural King stores have pallets of these in stock. Its not quite as dark green as the old stuff but pretty close
&lt;img src="https://www.yesterdaystractors.com/cvphotos/cvphoto54990.jpg"&gt;
OW
I use it.
RK has it at $8.99 and $3 rebate = $5.99
(quoted from post at 10:48:22 09/03/20) The other day I was in the auto parts store and noticed that the "old" Prestone antifreeze was no longer on the shelf. You know, the green stuff with the famous "silicone/silicate" additives. The closest thing they have is &lt;a href="https://prestone.com/products?detail=AF2000"&gt;Prestone "All Vehicles"&lt;/a&gt;. When I got home, I checked the jug of Prestone I bought last year for my tractor and was surprised to find it is also the "All Vehicles" Prestone, NOT the old stuff. This antifreeze is pale green in color, not nearly as dark as the old Prestone. Since it says it's compatible with "all" other antifreeze and doesn't say anything about silicones or silicates, I have to assume it uses organic additive technology (OAT). ("Organic" means "carbon-based", not that it's somehow good for the environment.)
There's no mention of the old Prestone on their website, either, so it sounds like they've discontinued it. They do list something called &lt;a href="https://prestone.com/products?detail=AF3200"&gt;Prime by Prestone "Conventional Green"&lt;/a&gt;, which seems like it must be similar to the old Prestone. I have no idea where you would buy it, if you wanted to.
utozone store brand says 'universal coolant, mix with any color antifreeze".
