oliver super 77
rustred
just wonder why this 77 has this style of front rims? the ones i have seen are open rims with the heavy hubs.
From what i understand they could be ordered with the heavy front wheels (the ones you describe) or the light ones (sheet metal) as seen here, although these are a universal implement wheel, the original olivers just had enough holes for the bolts.
I have a normal row crop S77. I didnt know they made them in standard, dont see many standard rigs here in row crop country.
Paul
The standard where the low profile Oliver's. And they where called a 77 Standard or 88 standard but where supers as for engines. Fewer of them where made also
i looked in my oliver book that is a standard tread. the row crop had holes in the tub for the cultivator pipes . the standard tread and industrial models didnt have the holes in the tub
All of the Supers I have seen had the bosses with threaded bolt holes instead of pipe holes.
The plain 66-77-88 had the holes.
Nothing really too exciting to Report at this Time. Working on getting the Front axle Rebuilt and Improved, with Induction Hardened Chrome Plated King Pins, New Bearings, and Rebored Center Pivot. Will be doing some Light Machining on the Live Spindles to Accommodate a Modern Grease Seal. Other than that, just accumulating New Parts as I can. The Lame Canadian Dollar is really putting a Dent in the ole Pocketbook!
Luckily, I Work at a Machine Shop!
