Onan ccka engine
SVcummins
Runs great for about the first two hours but after running a long time it starts missing I?m guessing that it?s something electrical ? Or maybe it?s vapor locking isn?t corn squeezins more prone to vapor lock issue ?
Yes,i think we went afoul using grain fer fuel. Soydiesel eats pumps n injecters,corn fuel vapor locks easy and sets longturns to corn syrup 9n the tank.
All this alternative energy is snake oil
I never had a problem with corn squeezins vapor locking me, but it made my poo a little runny.
Used to take a stick and put it in a crack of the silo and let the squeezins run off the end of the stick and catch them. Sort of like tapping a maple tree.
Loren
I forgot one other thing yesterday when it started running poorly I pulled the spark plug and and hooked up the wire and the spark was really weak today with the engine cold the spark was really bright blue and and a big spark
Got a CCKA on a welder that had exact same symptoms. Change the coil. Rather than go to an industrial engine dealer, I went to a Case-IH dealer and got one for a 1816-C for $175. After I ordered it, I found one on line for $39. This advice is assuming your charging system is functioning correctly and the battery is not going dead resulting in weak spark.
The reason I mentioned that was because I had a customer (innocently) pull a fast one on me. He had an LGT165 that would run tor 2 hours and quit. What I didn't know was that he would tow it into the barn and put the battery charger on it, and then have the charger put away before I got there the next morning. I was really pulling my hair out on that one! In your case 13.5 is exactly what you want.
