Ormco Power-Angel-Tilt Dozer Cylinders
Looking for kits for Densmore hydraulic cylinder 1.125 rod 3.00 cyl its a 1968 Case D310G dozer
Welcome to the Forums.
I am going to suggest you use the Case Construction online parts catalog to find the kit number(s) you need. The Catalogs show 3 different serial number range catalogs for the 310G and a number of different cylinders in each. You may have to check through descriptions to find the cylinder you are looking for. If you haven't seen the Case New Holland site below is a link to it. Enter 310G in the box about 1/3 to 1/2 way down the page, below the "Search Parts Catalog". Usually once you have part number to use in your online searches it helps. Baum Hydraulics may have kits, you may need to call them (as you should most places) not just go by what is shown online.
MyCNHiStore
