ph balanced antifreeze
skip33652
I recently had some bad luck with antifreeze getting on some john deere paint.it yellowed the paint.after posting on the john deere section I am wondering if this is not to do with a high or low ph,IE. acid or base. and if this is the case should I attempt to tamper with the ph? what would I use to lower or raise the PH? this is not the first time this has happened for me and I am not sure I want it to happen again.Thanks Paul
Use filtered rainwater to mix with your antifreeze and you should have no issues.
If you start adding chemicals to adjust the PH those chemicals will likely coat your cooling tubes and such. Causing cooling issues.
I suspect the reaction on the paint was due to the chemicals in the antifreeze.
What kind of antifreeze? What additives were in it? What kind of water did you use with it?
I only use Preston green, 50 percent distilled water, and an anti-cavitation additive. Tom
