Planting again finally.
fixerupper
Finally had the opportunity to spend some time in my favorite office yesterday afternoon. So far this spring the land I farm has been dry enough to plant for two afternoons only and then the conditions have not been ideal. Been having some trouble with consistent seed depth with the soil being so wet. The field cultivator brought up clods where the tractor duals ran and the ground is packed a little too much in those tracks but what does a guy do? The clock is ticking so we have to decide which is worse, take a possible yield hit from planting into soil that is too wet with inconsistent seed depth in the dual tracks or wait it out and possibly have a decreased yield from late planting. All of the electronics in the world doesn't help when the weather does not cooperate. The rain is coming down again today so the machinery is back in the shed. I am a little over half done planting so at least a little progress has been made.
I see your guidance monitor. And I see a planter mark. Do you have auto steer? I only use my markers when I'm doing end rows or on some irregular paths. I used to say I could plant as straight manually as any auto steer (probably not true but close), but after I started using the robotic driver, I really like it.
I just finished cleaning up the last pile of manure. If we don't get much more rain,it's possible that I could be planting a little bit by this time next week. The ground's still so cold though,I'm not that anxious to throw expensive seed in to it.
I see your planting at 32,100 pop. I'm planting at 32,500. Most say I should be planting heavier but I can never seam to pickup yield with heavier. Tried heavier several times with several varieties. Most in my area of s.c. Mn. are planting 34,000-36,000. Just wondering your thoughts and where are you?
I leave the marker down for two reasons. I havent come to completely trust the auto steer though it works fine. Second reason is For once, after 45 years of planting I can look ahead at a STRAIGHT mark. LOL When I plant end rows I could save the old line and go to adaptive curve, I believe it s called so auto steer will follow curves. I did use it once, worked great but it s easier to use the marker. Last spring while planting beans I turned around in the seat to watch the planter and in doing so I accidentally stepped on the foot switch and cancelled the auto steer. I watched the planter for awhile and when I turned around to look ahead I was pointed northwest instead of north. OOPS! And of course those rows were by the road. I am running on WAAS, it runs pretty darned accurate and The signal is free.
Last year I planted a 33500 pop but I backed it down a bit this spring. The talk in this area is the higher pops arent bringing in more yield for our soil type. This planter has electric motors driving the units so I can dial in a different pop for every row if I want to but I have never had the reason to do that. The picture is a little blurred. The evening light was fading away causing the camera to leave the shutter open a little l longer and i was jiggling and moving a little from the tractor motion. Took me six tries to get one this clear.
Holy baldy I would get lost with that much to look at while planting. I wish we could see the ground instead of the water. Rains about every 3 days. Not a seed in the ground here yet.
