Plastic plug removal
I'm just guessing here...
You have a PVC pipe plug that the head is chewed off so you can't get a pipe wrench or Channel locks on it?
What I've done is drill the middle out as large as you dare without getting into the threads. Then carefully grind out the center with a stone or Tootsie Roll sanding cartridge until the top of the threads just begin to show through the plastic. The remaining threads can then be peeled out, leaving the threads undamaged.
Going off how Steve summed up what you have going I will offer another possible solution. In a 1 in. plug you should be able to drill a hole large enough to stick a hacksaw blade ...broke off one held in a vise grip or plier maybe even a fancy holder if you have one...or even a saws-all if you have one. Carefully cut a slot out in the remaining section of the plug until you reach the threads. Be careful not to damage the threads when you get close to them. You may have to do this in a couple spots about a 1/4 in. apart. Then just crush the remaining part of the plug with a channel lock or drive it together with a hammer and chisel. Just buy a regular galvanized pipe plug and install it with a abundant coating of RTV on the threads. The RTV will hold down the corrosion on the pipe plug threads and you won?t need to crank it in real tight to make it seal. Other wise you could go all out and get a brass plug, I?m not sure how much one of those will set you back though.
