rrlund
I remember several years ago, Bison telling that he baled some hay that was so poor, when he got to the other end of the field, the bale was smaller than when he started. It happened to me today.
I had 8 acres on some ground that's such poor sand, you couldn't give it back to the Indians. We haven't had rain in five or six weeks and it's getting dire. That seeding is about three years old. We had a flash drought last year and by the time I cut it, it was as brown as wheat straw. I figured I'd better cut it early this year so it didn't happen again.
When I got there, I thought he must have rented it to somebody else and they had sprayed it with Roundup. It looked like it had been sprayed as soon as it started to green up six weeks ago. The owner came out and waved while he was walking to the mailbox and didn't try to stop me, so I kept cutting. I raked it today and went back up and baled it. I had about a two foot bale after about three and a half rounds, but that was as big as it got. I baled the rest of the field, and that was all she wrote.
There were placed where I was shutting the baler off. There was nothing going in, so I didn't see the sense running it while more was coming out. Hay was going to the outside edge of the bale, slipping up between the outside belts and the sides of the baler and coming out. Some was coming out the front and falling back down in the pickup, the rest was going out the back as well as some being so fine it was just going over the bottom roller and right straight out I guess.
When I got home, I kicked it out next to the wall in the bunker silo. I stood beside it and it came up about to my jackknife in my pocket. I thought I was being a little pessimistic when I thought there might only be five bales. I guess that would have been good. Thank God none of the rest of the hay looks that bad.
I turned over some alfalfa that got three quarters inch rain on it 2 days ago. 4 acres of reclaimed ground from building the ponds in the golf course. Clay and just dead ground. I doubt there will be 30 small squares o it. What a waste of time. I like your neighbors saying bale was smaller at the other end then when he started. Okay if I use that line?
Feel free. Bison said it first. I was skeptical when he said it, but it can happen.
I finished baling the ten acres in front of our house Sunday afternoon, last year I put up 1125 squares, this year, 373. The alfalfa leaves are just lace-I figured it was the late frost we got, but I pulled some plants before I cut and found weevil.
A small field I rent from a neighbor I seeded last September, the grass looks okay, but not a single alfalfa seed sprouted. Not sure if the seed froze before I planted it, or what happened.
Thanks goodness I was approached to mow and bale a small field next to a nearby church- the weeds outnumber the grass, and it is the roughest piece of ground I have ever cut, but it will feed better than snowballs next Winter.
I've seen hay so poor (not this year), that you couldn't really see that any hay came off the side delivery rake after one pass. Maybe have to guess where you drove before in places on the second pass when trying to rake it over further to even come up with a visible wind row.
When it's that bad, I really don't think you even come up with enough hay to even pay for the fuel. But I have been known to try and get what I can when I know I'm gonna be short on hay. But even with that said, I don't think I've messed with hay so bad that it wouldn't even make a bale. But, I do rake with a single side delivery rake, so I can just keep raking it over until I got enough raked up to make a descent wind row. But, about 3 passes is where I draw the line. If 3 passes isn't producing any hay worth while, I just throw in the towel. Clip it off and leave it lay.
(quoted from post at 19:56:53 05/31/23) I remember several years ago, Bison telling that he baled some hay that was so poor, when he got to the other end of the field, the bale was smaller than when he started. It happened to me today.
think you are just funnin us.....I feel sure that you can look at a field and see whether there is something or nothing there to bale?!
I was using a V rake so I was raking double, but baling the second round, I got off to nowhere. There was no windrow to even be found. That was when I started shutting the baler right off in the middle of the field. Like I said, when I cut it, I figured there'd be five or more. I baled poor third cutting one time where I had five on sixteen acres and I thought it'd never get worse than that. When I got done this time, I figured hay would have to be five hundred dollars a bale to make that worthwhile.
Hate to heard anyone having that poor of a hay crop
Worst I ve had was short of 10 4x5 bales from 20 acres
I ve seen a couple of fields that would have probably made less, but I didn t bother cutting it
We ve had a lot of cool spring nights so hay is running a little late to fill out, but the 15 acre field I reseeded last fall turned off some good hay making 142 4x5 bales
I baled two fields of mixed grass on better ground today. Didn't set any records, but it was at least average. That
bad field was an anomaly. It's only a mile and a half straight north, but it's so sandy that it's a whole different
world. All of the lawns up there are dead as a door nail too.
I had one field ready to bale this afternoon, another tomorrow. About 3pm, the sky darkened and it sure looked like rain. I put everything away just as the sprinkles started. Temp dropped from 90 to 68 and we got a half inch of rain! Happy to sacrifice the two fields in exchange for the rain. Lightning took out our router, working off my phone for a day or two...
I put down another 20 acres Tuesday, was out tedding it Wednesday and go fought at the far end of the field by a pop up shower that rained 1/2 inch in 20 minutes. By the time I got back to my pickup I was soaked
Tedded it again yesterday afternoon and plan to bale it this afternoon
