Problem bleeding fuel filter
Philip498
I have a 3600 Ford diesel tractor on which I replaced the fuel filter. According to my owner's manual I now need to bleed air out of the fuel filter by loosening the bleed screw on top of the filter housing and waiting until I see fuel flowing out of the housing by gravity. My next step would be to open the bleed screw on the injector pump and bleed air out of the system by cranking the engine over. My problem is that I can't get past the first step. No fuel comes out of the bleed screw on the filter housing even if I take it completely off the housing. I have a full tank of fuel and I have even cracked the coupling on the fuel supply tubing where it attaches to the filter housing. When I do that I can get fuel to flow out of that area so I know the fuel valve on the bottom of the tank is working. Why can't I get fuel to flow out of the bleed screw on the filter housing? Any response would be appreciated!
Yes. After I changed the fuel filter, I turned the fuel valve back on and I know that fuel is coming through the tubing up to the fuel filter housing.
Yes. Maybe that is what I need. Not sure how long it will be before I see fuel coming out of the bleed screw but maybe I didn't wait long enough.
Still no fuel coming out of the bleed screw on top of the filter housing. Thinking that maybe fuel flow was blocked going into the filter housing, I loosened the retention bolt to remove the filter to see if there was fuel coming out of the supply line. I no more than loosened the retention bold and had fuel coming out all over from on top of the filter so I know that the filter is getting fuel. Why it is not coming out of the bleed screw is beyond me! I would like to see fuel coming out of there before I attempt to bleed the fuel injector. Has anyone else had this problem in a Ford 3600?
I considered something like that. As it is, the fuel tank is full right up to the filler neck. In fact, there was more fuel in the tank than I realized and it ran over when I put more fuel into it. I
am thinking that giving a short, air burst into the hole where the bleeding screw fastened may be in order. Will try something like that when I get back to the job. This has to be a simple
problem and should only need a simple fix.
I seem to remember having a fuel filter many years back that flowed one way. Could this filter be installed backwards? Is there an arrow anywhere on the filter housing?
Xs 2 what welding man said, make sure the filter top outer groove does not have an O ring in it. That's the filter inlet passage. Lost count how many service calls to correct that common mistake. The filter top is sealed by an O ring in the base groove.
Good advice! I will check on that tomorrow when I get back on the job. It has to be something simple like that. Many thanks to all who offered advice!
O.K. I am now back in business! I did have a Wix fuel filter and I did have the gasket in the groove in the top of the filter. I removed the gasket (i.e. large O ring) and reinstalled the filter and got instant results in bleeding it. This forum is great for folks like me. Many thanks to all who commented on my problem!
What brand of filter is it. If it is a NAPA OR a Wix you put the O ring in the wrong place,
I know this is an old thread, but I wanted to thank Welding Man for the tip on the top o-ring (or the correct lack thereof!). Saved me a ton of anxiety on why my tractor wouldn't stay running.
