Problem on steerig on MF 253
Richard G.
I posted this down on the MF board, but thought it might get more views here.
Friend has this MF 253 that bought recently.
Steering problem. It would steer some when he bought it, but has been getting worse quickly.
Pump is full of fluid.
Cranked it up yesterday and it steered hard to the right, but would not steer back to the left.
Used the loader to pick up front wheels.
If you try to turn left and then let go of the steering wheel a second and try to turn again, it will come back to the left.
Just sitting and running, the steering wheel moves very slightly back and forth by itself.
Shut the tractor off and the steering wheel still moved back and forth slightly by itself.
Could it be air in the system?
Temps here have been in the 50's and 60's for a week.
What fluid is used in this?
Any ideas would be appreciated.
Richard in NW SC
My "guess" is there is a problem in the Orbitrol unit. Likely a broken return spring, or pieces of something jamming the directional valve.
You can try taking it apart, see if anything looks out of place.
But if you do take it apart, be extremely observant, mark every piece, take pictures, make notes. It MUST go back together exactly as it came apart or it will do strange an dangerous things! Like violent steering wheel oscillation, or spin full to one direction! Keep your hands clear and steer with caution until you trust it.
Probably be best to just replace the Orbitrol.
But, there could be pieces of metal in the system if there was a component failure. There is a filter in the steering pump. Might take a look, cut the filter open see what is there. It will be very difficult to get it all out short of opening the cylinders, flushing the lines, but you sure don't want it getting in the new Orbitrol.
There may be some air in the system. If the fluid is milky, there is air whipped into the oil. It will eventually purge out, usually when sitting overnight. As long as the level is full it will work it's self out, but as the air leaves, the level will drop. It takes several topping up to keep the pump from getting more air in the oil, and it may puke oil when the engine is stopped.
But air should not cause the non steering as you describe. The shaking, yes, but not the non working.
When was the last time the filter was changed/cleaned in the power steering unit. Inside the pump oil container their is a filter that has probably never been changed cleaned. Looks like a bolt head on the back opposite from the pump.
