proper 3pt disc set up
Leon R
I am using about an 8 or 9 ft jd tandem 3pt behind my MF65 gas. Right now I am using a chain as the top link to try and keep the rear disc section from floating above the ground and that is not working very well. Is there a correct way to set them up so that the rear does some work?? I have extra weight as well on the back. Should I be using the rigid top link? Would that keep the back down. I went to the chain because that wasn't working either. Maybe it is just the way they work??
If it's a 3 point mounted set of discs, I would think the top link needs to be rigid, so you can adjust the front to back level of the gangs. Also adjust the level box on your lift arm so it is level side to side. I am not familiar with the model you listed, but would also think that it should have an adjustment for the angle of the gangs, the sharper the angle the more it will cut and slice, may also leave more of a windrow in the middle when in deep/loose soil, one of those things you adjust in the field per the conditions you are in. You may want to be careful with too much weight, rocks, when in turns you had best lift the gangs out of the soil, as well as the extra weight on the bearings. I don't use weight with the 3 pt set I have, I just make extra passes and try to do it when the soil is soft and cuts easily.
Use a rigid top link and crank it out so it pushes the back end down (will want to lift the front up. I also use stabilizer bars to keep it from swaying back and forth too much. I dont use any weight, sometimes i have to pick it up some so it doesnt cut too far down. Also by changing your disc angles you can change the depth of cut. After you have disc'd one way over the field then go 90 degrees the other way all the way down.
Thanks guys, I just changed the top link to rigid and adjusted it to keep the back down. I notice now that the front gang doesn't cut as deep but that is OK. I am working up about 7 acres of alfalfa/grass after spraying it with roundup. It is hard and dry so am hoping for some rain before I have go at it again. Just too dusty now after the first couple of passes.
