Question for billonthefarm
How hard was it to take out the steering valve on your 3010. I got to on my 3020. How did you take off the dash. You leave the gauges on the tractor or with the panel. How hard were the 4 bolts holding it on was it to break loose. Thanks.
I left the gauges with the tractor and that helps some. The bolts werent that hard to break loose. I think you have to stick a long extension and socket in from the right side to get to one. Some of the lines are unhandy to get loose. Going back together is a bigger pain. You will probably want some help to hold it in position while you get the bolts started. Hooking the lines back up was the worst. Hard to get everything just right and its pretty tight but you will be fine, just take your time.
bill
Just one more question before I start on it. Did you lift it out with help from somebody or some kind of overhead lift. Thanks again.
