Hoping you can help me out with Roosa pump timing on a 310 indirect out of a 1800. ( now with 4 1/4 inch pistons but same 4 3/8 stroke) This is in a pulling tractor that turns about 3500 RPM. I broke the camshaft a year ago and since putting in another cam the darn thing does not seem to lug very well at all. I had Cam ground identical to the old cam and set cam timing the same. What I am not sure of is were I had pump timing? ( To make a long story short I lost the paper I had written it on, but thought it was around 20 degrees before TDC. I have tryed it there, at 17 and at 14 and still does not have anywhere near the lugging power it had before. Ideally I would put on a dyno but dont think thats going to happpen this pulling season as I dont have a PTO shaft in it or the drive hub for same in flywheel. ( PTO clutch might not take it anyway??) So my question to you is were would you suggest a good starting point for pump timing be? Also is there any gain in playing with the tourqe screw?
