Question on Tire sizes
aron5
I have a tractor with 12.4-28 tires on it and I see there is a coversion tire that is 320/85 R28
Will these fit are they the same size? will they mount the same lookslike these conversion ones are radials ?
320/85R28 is a radial conversion from the 12.4-28 bias size. It will fit and mount the same however they may look a bit different. Depending on your tractor and the rims on it which may be for tube type tire, you might need tubes in them even though most radials are designed as tubeless tires.
I've never liked radial tires on tractors, but it's becoming standard on new ones.
A new Firestone 320/85 R28 is $1,125.59. A new Firestone 12.8-28 is $545.79.
