Re: Ford 3000 highway
caterpillar guy
With a puller on it if you can put some heat to it should pop loose. Do use a nut on the threads when using the puller to keep from deforming the threads on the end. Better would be a plate over the end to pull on.
You've probably already busted up the plastic
around the center hub on the steering wheel.
Take an angle grinder with a cutting wheel
and cut the center hub from top to bottom.
Then replace the steering wheel.
They sell them here.
They are not too expensive.
As to the handbrake, if there is no more
adjustment then you are looking at replacing
the discs.
I had a 4000 with that feature. Parts were
almost prohibitively expensive.
The seals in it were all shot and it was a
major source of water getting into the rear
end.
I simply removed the whole unit and replaced
it with the typical round cover from a
boneyard.
