RE: Kirk Grau
Your thread about your fuel dilution has been pushed down the second page, yet I noticed that two other individuals made a very good point about the lift pump. That is another point where the fuel has the opportunity to enter the lube oil system. Have you had any success with your troubleshooting?
Thanks for keeping up with this Bob.
The 3600D is gravity fed to the injector pump, so the lift pump is not applicable for me.
As I understand the 3600D there are only the 3 points (Thermostart, injector pump, and injectors) to cause dilution, and I have attacked the first two now. Maybe somebody will speak up with other information.
Tractor seems to run so well otherwise (smooth, no smoke, good power), I have kind of discounted injectors, but might have to start looking there as well. Right now my bigger concern is getting the governor/throttle correct that I seem to have messed up myself so I can at least continue to use the tractor.
Kirk
