Rear Remote Help
Pete_5959
I want to add two rear remotes to my small tractor. I will be using one for a Hydraulic top link and the other to control a three point
sickle mower. Would someone enlighten me on what type valves I need to purchase? They offer kits one a float valve kit and the other a 1st
position valve kit for this tractor. Thank you for helping out.
r/
Pete in NC
It would really help if you stated what your small tractor make and model is! We are good at guessing, but not that good!
Talk with your Kubota dealer. My New Holland dealer added extra remotes to two tractors for me. A dealer installed only option for me as I don't like to cobble things together.
Did something very similar to a White 2-105. Worked great. Doesnt seem like you need much flow, so it should be easy. First, youll need to identify any port where hydraulic flow can be accessed. Then youll need to know if your system is open or closed center. I used Prince SV sectional control valves (both double acting cylinder spool with float position). Others might work as well, but the SV valves fit my needs, and are relatively small (easy to mount). Surplus Center is your friend. Valves, hoses, fittings, quick disconnects, adapters. Got it all there.
There's a person on you tube that makes and sell kits for rear remotes,I got one this summer for a Kubota. FredWi
