Rear tractor tires
tldnc
I am looking at a pair of 13.6 x 28 rear tractor tires that are long bar short bar tread. What if any are pros and cons on the long bar short bar treads?
Thanks for all your responses.
Really depends more on the ply rating and construction and radial/bias ply, as well as your intended use. These are more important than the tread bar design. They work well, but the other factors are more important. Jim
They bite good on soft ground and clean good in muddy wet ground. They do not penetrate and bite in good on hard ground when pulling heavy draft equipment like plowing on sod ground, especially after they have some ware and the lugs are rounded off a bit.------------Loren
I agree with Loren. Generally speaking they are not very well liked by tractor pullers. You don't often see them at a tractor pull.
I would NEVER but a 23* bar tire ever. Had way too many of them. No traction, wrap in mud.
(quoted from post at 17:09:53 09/03/19) I am looking at a pair of 13.6 x 28 rear tractor tires that are long bar short bar tread. What if any are pros and cons on the long bar short bar treads?
I still have one set but have pretty much gotten away from them.
Had a set on my 4000 for 20 years and they were a decent all around tire.
Reason we're getting away from them is our farming operation is expanding with more road travel, that thread design doesn't wear well on hard roads, also at certain speeds they will cause the tractor the shake and vibrate all over.
Replaced the Armstrong long-short on my 4000 with Firestone SAT II's, ride good, decent traction, but their narrow lugs are wearing out fast, no more SAT II's for me.
Nephew is getting good service from BKT's.
What you want is the 23 degree bar tires. They probably outsell all other designs by 10 to 1.
