Rebuilt Generator
super99
I had the 12 volt pos ground generator rebuilt for the 550, put it back on and when it started it was charging. I thought it would have to be polarized before it would work. Chris
(quoted from post at 20:01:45 05/05/20) I had the 12 volt pos ground generator rebuilt for the 550, put it back on and when it started it was charging. I thought it would have to be polarized before it would work. Chris
ASSUMING the rebuilder tested it on a test stand with it correctly connected (+) ground it was already polarized when you got it, and correctly.
Likely, it could have laid on a shelf for 20 years before you installed it it would have still charged, as well.
Where people get into trouble is if the generator was run/tested with the wrong polarity or POSSIBLY taken apart, put back together and NOT tested.
In such a case, if it charges "backward" at startup it can destroy the cutout relay points when they close, or weld them shut, which will discharge the battery through the generator and let the smoke out.
It never HURTS to polarize, as long as it's done correctly for the type of generator you are working with (either an "A" or a "B" circuit), but it must be done BEFORE the first startup with the replaced generator to keep all the $$$ smoke where it's supposed to be.
Another "myth" is that the generator needs to be polarized any time the battery has been disconnected or a new battery installed.
So long as the generator was charging BEFORE the battery was disconnected or changed it will charge correctly afterwards so long as the battery is connected with the same polarity as it was before.
Another old tale is that a hard drop of the generator or hammering on it can screw up it's residual magnetism, LIKELY true, but I don't know for sure.
Chris, great question, "I thought it would have to be polarized before it would work" here's the deal:
A Generator should be correctly polarized BEFORE starting, because if its at opposite, VR or other harm is possible. A Generator still "works" at EITHER polarity but you obviously need it to match the battery well duh lol
HOWEVER if yours was already correct it can work fine and its not necessary to repeat it, but to be on the safe side if I'm not sure I would polarize before starting
If a genny had been at the shop Id definitely polarize before start up.
Hope this helps
John T
The generator housing holds residual magnetism and may not always needing polarizing. Years ago a company made aluminum generator housings for Harley but the generators did not work because the iron or steel housing is part of the whole system. Reduced weight but no charge.
If polarity is wrong, it will polarize it's self, WITH a nice fat arc at the cutout contacts. Not good for those contacts.
I figure more have been ruined from polarizing than not ! We had a saying at the rebuild shop. If it had more than 1 wire the customer will likely get them hooked up wrong !
Thanks, I thought that it had to be running to polarize the generator, learned something new, now just to remember it!!!!
