remanufacturing button clutches
Cas
I have had excellent results relining my own
fiber tractor clutches. I was wondering if
anyone on this site has done there own button
clutches and pressure plates? Also, if you do,
where do you buy you supplies?
thats what i do , just take it to a brake and clutch shop and tell them i just want the lining replaced. they try making excuses so they can sell you a complete rebuild.
The problem with just relining them is most have a spring damper assembly that also needs to be rebuilt. When you get into the larger size clutches you will find that the rebuilt clutch disks have been rebuilt using all new parts. The only thing reused is the part number.
I agree with Owen, I put a rebuilt disc in my Farmall 400, the lining was still good on the old disc but the spring damper was loose/worn more than I thought it should be.
