removing rust in carburetor
there is a lot of gritty rust in my 400 case-0 matic carburetor..it is cast iron ,,. i have some muratic acid but i recall using it on a aluminum or pot metal carburetor to clean it and the metal started to dissolve ,,..maybe you guys have a better solution ,,.please post back with your ideas.
I use end brushes, of different sizes, with a cordless drill. Cast cleans very well with these and any pit that won't come clean can be hit with muratic acid or rust dissolver.
(quoted from post at 13:38:03 04/13/23) I use end brushes, of different sizes, with a cordless drill. Cast cleans very well with these and any pit that won't come clean can be hit with muratic acid or rust dissolver.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto152251.jpg>
Vinegar 1part , water2parts in a stewing pot .Send your wife to the grocery store first. Medium heat for 1hr .stir carb and related parts occasionally . Then get it off the stove and back to the shop before she returns. do not ask me how I know this! CM
Yup, muriatic/hydrochloric acid will dissolve zinc, magnesium, and most pot metals. Phosphoric acid (naval jelly) is a little better and generally a better choice for rust removal, but leaves a residue behind that I'm not sure I'd want in my carb. Products like 'Evap-O-Rust' will be fine on most metals but also leave a residue, and generally work like crap. The vinegar solution Chuck Machinist suggested and a soft-ish (brass or nylon) brush is your best option. Don't go at it with a steel brush as it's harder than zinc/pot metal/magnesium.
Hi:
That sounds effective and gentle. I was looking for something to use on my honey extractor. Not quite case related or motor related but I thought I would ask. The cages (metal) which hold the honey frames is what I would like to clean up.
Thanks for letting me but in.
I do as Chuck Machinist except I have my
own slow cooker in the shop. I might add a
couple of drops Dawn dish washing soap.
(quoted from post at 00:21:40 04/14/23) I do as Chuck Machinist except I have my
OK! A little Dawn for Aroma! CM
The product I have used and have had AMAZING success with
although I hate the name of the product it works extremely well
is Evapo-rust.
it is a little pricey but WELL WORTH IT!!!!
JPC
(quoted from post at 11:40:07 04/13/23)
Vinegar 1part , water2parts in a stewing pot .Send your wife to the [u:fceff74570][i:fceff74570]JEWELERY[/i:fceff74570][/u:fceff74570] store first. Medium heat for 1hr .stir carb and related parts occasionally . Then get it off the stove and back to the shop before she returns. do not ask me how I know this! CM
b:fceff74570][/b:fceff74570]
Fixed the wording in your post Chuck. :D
(quoted from post at 00:53:40 04/16/23)
Vinegar 1part , water2parts in a stewing pot .Send your wife to the [u:dcda851397][i:dcda851397]JEWELERY[/i:dcda851397][/u:dcda851397] store first. Medium heat for 1hr .stir carb and related parts occasionally . Then get it off the stove and back to the shop before she returns. do not ask me how I know this! CM
b:dcda851397][/b:dcda851397]
THANKS! CM
