replacement plow points for a plow
Tanya Cable
Does anyone know where to purchase replacement plow points for an old Model#10-152 Dearborn plow? Thank you for any assistance.
Take your old share off there will be a number on the back or on the edge of the share. Get back to me I am associate of Crescent Forge maybe I can help you.
I am also looking for parts for one of these. Shins #104428, Shares #104405, Landsides #104355 & 104356. I was very disappointed to read elsewhere on this forum that Crescent may be out of business. Is this true?
Thanks, Dave. I've been looking there but cannot tell exactly what's what - I see parts for ford "152" plows, but this looks to be a much larger 18" plow. I understand this 'dearborn' plow was either made or sold by ford, and that some Ford plows used Oliver bottoms, but the more I look for parts, the more I'm confused about what will/won't fit. I have a manual with part numbers but none of them match what's for sale, except from crescent. Can you educate us (me) what ford plows we should be looking under in order to find the right parts?
Ok, Points? you mean shins? shears? or slides?
Theres a farm dealer up here by me that has 7 OEM shears for derborn plows with 14" moldboards, but fit 12" also. 3 are for LH 4 are for RH. I got shins and slides at another dealer, all are Import made, real junk. But all i could find locally. Can get other shears for someone that needs them. Have 3 bolts, but you can cut back to 12 length if you deisre, but not needed.
Mfg date, and FoMoCo stamped on shears i got 1-58, 7-60 so there OEM.
Posting an update in case it helps others:
'F-shin' as available from local Tractor Supply Company or from Agri-supply definitely fits - I got mine this weekend. Gotta love Ford - apparently this 1 shin fits pretty much all ford plows over a 60 year period.
Also got shares at TSC because of the same modular design features. Shares for the more common 14 and 16" plows bolt right on - all use the same bolt pattern. Osmundson (USA MADE) were $14 each. P/N was OF14 or OF16. I bought 16" because they were $5 each less than 14" (go figure) with the intention of cutting them shorter.
Can anybody advise as to what might happen if I leave them long? ( I've never run a moldboard). Thinking of cutting to 13 or 14".
Now I'm still looking for landsides. 104356 is Ford# for the front. It appears Osmundson makes a match for that - I'm waiting for TSC to get me one of those. 104355 is the rear, but the Osmundson book shows that their rear has a different bolt pattern. Could be a goof in the printed book. Waiting for TSC to get an answer on that, but if Crescent reopens soon, maybe I can get one there. I'll post again if I figure out what to do for these Landsides. Hope others get as lucky......
PS - Found a good source for the 5/8" plow bolts that attach the landsides - Wilson Finley online has good selection of fasteners that are harder to find locally, and price is very reasonable. Check them out if you find the 5/8 plowbolts as rare as I found them to be here. Guess No-Till farming has wiped out all knowledge of the old moldboards, as well as much of the spare parts........ Thank goodness for the internet and seasoned farmers!
