Schebler carb Model TT ?????
I have a Schebler carb that says model TT on the side of the lower casting in raised letters. It also says TT-29-A in stamped letters on the bolt flange for the incoming air side of the carb. It also has the letters T28 in raised letters on the upper half of the carb castings.
I had posted an inquiry in the Minn-Moline forum a week or so back, as this was taken off of a UTIL -Moline U Industrial.
I would like to know what other tractors (Brands/Models) may also have used this carb and if it is in fact a Schebler TT or TTX carb. I seemed to get a few different opions on my first post. Since then, I did more cleaning and found the TT-29-A stamping.
The top or mounting flange measures 3 5/8" at tips of the flange with a 2 5/8" bolt spread. The intake from the air cleaner has a 4 1/4" flange and a 3 1/4" bolt pattern. It does have a different body style than a TSX or TRX carb.
Thank you for any help.
Looked this afternoon and one lower TT carb casting I have said T-29 by flange and the other one showed T-29A. The choke lever linkage is on opposite sides so maybe why the A was added on number. They fit MM MT MTA Universal tractors and possibly some others. You have a Schebler TT carb. The NOS bowl castings I have came from a old MM dealer and says Schebler TT on the side plus the T-29, T-29A and G4 numbers on side. Schebler, Marvel Schebler, Zenith, Borg Warner, Facet carbs are now owned by Zenith Fuel Systems. Only parts break down or other info I have on them are in a MM Universal and MM MT parts books that show only the MM part numbers for TT Schebler carb. You might post on JD forum trying to raise Duane Larson to see if he has any other old Schebler info for you. Early JD carbs were also Schebler.
