Screeching noise under dash
snipesrr
I have a Farmall 35, 2009. In the past few years I hear a loud screeching noise from under the dash whenever I am moving along in high gear. Rarely does it in low gears. I let off the foot pedal and it stops, start moving again and it comes back, but not all the time. It sounds like the sound of a odometer cable back in the old days when cars had them. Any ideas??
Snipe welcome to YT! I am sorry but your ..Farmall.. is
not really considered a ..yesterdays.. tractor here even
though it is 14 years old. You have a re-branded
Farmall built by Shibaura which is a Farmall by name
only. The tractors discussed here are mid 1980 and
back to the early 1900s. Sounds like your hydrostatic
drive has some type of an internal pressure leak or
something like that. Maybe a chance someone here
may have some info for you. You might try the ..Tractor
Forum.. Repair and Technical Discussion section. The
guys over there are way more knowledgeable on those
CUT machines ..compact utility tractors. I will see if a
link works I think this site usually blocks this.
X Forum
(quoted from post at 17:04:17 10/07/23) Should be someone on the Red Power forum that can help, too.
Mike
Thanks for the feedback, but not sure what the Red Power forum is, but will look for it.
