Sediment bowl question
Tgrasher
Will teflon tape work on the threads to seal at the tank? Anything else that will work? Mine tightens just past where it needs to be and I don't think it will
make another round. Don't care to experiment and have a gas mess.
"Gasoila" sealant.
They make a hard set and a soft set version. I'm gonna GUESS the hard set version would be best in your situation.
One other idea would be to try a spare sediment bowl if you happen to have one, and carefully tighten it so you don't pass the correct point for fitting the line and need to loosen it.
My plumber/gasfitter pal has a whole range of 'brush on' sealants. You might look into those products. Apparently Teflon tape is no longer used by the 'pros'. HTH
or just go another round...live it up...in was scared to go another round but it made it an did not leak with no sealent....on farmall tanks........dewy
