setting valves on 3130
john ross
How do you find top dead center on a 3130, wanting too set the valves and there is no mark on the fly wheel is there another way too tell when you have TDC. thanks for anying info.
john on right side of engine thers a plate small in size that has apin sticking out remove bolt trun it around and install small pin in the hole press it agenest fky wheel as you trun engine over BY HAND intell you fell it slipe in to recess in fly wheel at that ;point you have engine on tdc could be on #1 compression or #6 compression but you can tell that by the valves. some of thies hole are on left side of engine
