Soil recovery methods
550Doug
Location
Southern Ontario
I'm looking for ideas on rebuilding my potato plot in as natural a way as possible. I have used a rye cover crop in the fall that I plough under in the spring, but now I want to rest that area for a year or two and get the soil in better shape. I can get some old composted cow manure and even some maple leaves that I hear can really benefit the soil, but are there any other ideas that could help to rebuild the nutrients and minerals in the soil that also boosts earthworm populations?
Organic material that is PH balanced can be very effective tilling it into the soil is necessary to assure it contributes to the composition. Leaves are often higher in acid than
desired, so application of lime can accommodate that. Soil testing (from the extension agent, or self testing with good tools is really essential. Jim
Organic matter is the key, add those leaves. grass clippings would be great. Find some old hay or straw to put down and let it all rot then turn it in to the soil.
I worked years and years ago with an old fella that was quite a gardener ...... he grew stuff in areas and in soil that others
wouldn't even consider trying to grow anything in. Not sure what he did to be so successful, I suspect a lot of compositn
(done correctly). He cursed earthworms till the day he died ..... well, he cursed "too many" earthworms till the day he died.
He said once the earthworm population takes off, your garden plot becomes like concrete and you might as well use it for an
airplane runway. That was his story and he stuck to it ...... till the day he died .... LOL !!!
I definitely 2nd the recommendation to talk with your extension agent. Lots of bad stuff out there.
I bought half a pallet of composted bagged manure from local ACE store; some last year and some this Spring. Everywhere that we used that manure, whether mixed with soil or straight, ended up with a nasty looking kind of scale or rust on the taters. If we used just soil or our own compost, the taters were picture-perfect.
Alfalfa or other deep-rooted legume as a cover crop will add nitrogen and loosen subsoil. Just bush hog it off when it gets too
tall and it keeps growing back. Then plow it under before planting the garden next time.
You can't do better than the cow manure. If possible get both composted and fresh. You can get roughly 15-8-10 from it along with a lot of tilth from fresh dairy cow manure. Leaves and grass etc will add tilth but as Janicholson said you will need more lime.
Here in the south east corner of Pennsylvania is the big mushroom growing area
of Kennet Square. There are several sights for prices of mushroom soil.
Composted horse poop and hay that is sterilized and used to raise mushrooms.
There are outfits that will even deliver it. There are a variety of prices but
this stuff is like the premo for gardens. You need to really till it in with a
big rototiller machine to get the best results. Gardeners just love this stuff.
Have no idea how far away you are from these growers but a large trailer load
might be cost effective. The others have said mulch / rotten hay, lime,and
manure, but it all takes time. The mushroom soil is pretty much ready to go.
Speaking of cow poop. One time when I was a kid my dad thought it would be a
great idea to "Fertilize " the front lawn. Yup I can't remember if it was one
load or two loads of nice JUICY poop from the girls. Had to take a garden hose
and wash the sidewalks off. WELLLLLLL about a week latter the grass got the
jolt of its life after a good rain. Just imagine mowing your lawn with just
slightly dry cow all over. A couple of weeks latter the weed seeds in the poo
took off. Was an excellent exciting summer. I will say that lawn for several
years after was very luxurious.
(quoted from post at 16:40:52 10/02/19) Back in the day I hear they planted buckwheat in the fall, then tilled it under. I haven't tried it.
MarkB MI, that is called "green manure" it is common practice to plant a green manure crop in the fall right after harvest and till it under in the spring to add nutrients.
Do not get carried away with adding lime to counter act the acid caused by adding leaves, manure or compost. Most garden crops except sweet corn and popcorn prefer a slightly acid soil of 5.5 to 6.0 ph. The closer to 5.5, the better. Good luck!
I have used pellet gypsum for root crops. I put it on the entire garden area.It really helps loosen the soil up . Also a little masons sand. I get the gypsum
at Rural King .
Adding, grass, leaves or compost, well rotted
manure, will all help, try green manures like rye, as
you said, buckwheat is great for smothering weeds
and adds a lot of matter back to the soil so it?s a
super soil building crop, when tilled in, you could
also plant peas or green beans as green manure
and have a crop to harvest. Legumes are also good
for putting nitrogen into the soil. You also dident say
how big the area is, so some of this may not work
for you, get a soil test also.
Be cautious of too much dry organic matter like leaves, hay, straw, or sawdust. They are very high in carbon and will tie up any available nitrogen for
the near future. What KCM talked about below was likely scab. Too high of a PH promotes scab on taters. Longer rotations and lower PH helps prevent
it.
Doug,
I've composed about everything from woodchips, leafs, grass, cow poo,
horse poo, coffee grounds, kitchen scraps.
Some have long term benefits and short term dissadvantes. It will take
more grass and leafs than the average person has. Some gardners find a
person who bags grass and leafs. It will take truck loads to make a big
difference.
If there are seeds in hay the animal eat, their poo will plant seeds in
your garden.
If you use grass clippings and pick up crab grass or weed seeds, you'll
be planting weeds.
It seems like composting material for a year or more, you'll still have
seeds that have survived.
Some gardening sites recommend wood chips for mulch, retains moisture
and when it composts on the surface it will add neutrants.
I have added leafs to surface of garden in fall. By end of summer most
of the leafs are gone.
Add grass to surface and it will compost faster than leafs. If you
compost grass with dirt, it will smell like horse poo.
I used to get horse poo and sawdust saturated with horse pee. The
sawdust was high in nitrogern and composted fast.
Worms in garden is lunch for moles. Normal year I trap many moles
dinning in my garden.
Bottom line, there is no easy fix for the average person.
To plant this time of year Crimson Clover with some Hairy Vetch mixed in is about as good of a soil builder you can plant,it'll come up and then over Winter and come out strong next Spring beautiful blooms and Honey Bees love it.
(quoted from post at 18:28:12 10/02/19) Do not get carried away with adding lime to counter act the acid caused by adding leaves, manure or compost. Most garden crops except sweet corn and popcorn prefer a slightly acid soil of 5.5 to 6.0 ph. The closer to 5.5, the better. Good luck!
Olyjay1947, I googled it here is what I found:
According to the National Gardening Association, the recommended pH level is between 5.8 and 6.8, although some other organizations recommend between 5.5 to 7.
When the pH is below 7 the ability of the plant to take the nitrogen up is reduced.
Soil scientists will tell you that it takes 100 years to build an inch of soil. Adding organic matter will help, but don't expect that it will "create" new soil.
There is no need to worry about adding weed seeds. Unless you are taking all of your current soil up and sterilizing it you have plenty enough weed seeds already in it to grow ten weeds per square inch, LOL.
check with local egg producers and hog houses, I would think complete coverage with dead chicken and piglet carcasses would create quite the buzz in your gardening community, AND improve the soil. Is there a rendering plant nearby?
(quoted from post at 22:52:21 10/02/19) Be cautious of too much dry organic matter like leaves, hay, straw, or sawdust. They are very high in carbon and will tie up any available nitrogen for
it.
Are there any long term benefits in adding wood chips to the soil? For example, will it after a couple of years maybe lower the ph?
