It appears that it you have a wallet thick enough you can get any bearing you want. There are a million of them.
What spec bearing should I be looking for for my '40 H ? I see bearings with 15 or 17 balls that are R or P clearance spec but can't find anything that defines what that means. C0 and C3 are both pretty common but what is appropriate for a gearbox on a work a day tractor ? If the shafts flex, too tight is not good. Too loose seems like a problem right off the bat (see the chipped tooth on the layshaft).
IIRC, the bull pinion shaft bearings had 13 balls originally and lasted 50 years. The CIH replacement in the '90s had 11. They last 10-15 years. Seems like more is better.
As a bit of background: This is a working tractor. It has a chipped tooth on 3rd gear on the countershaft in the transmission. In my mind not replacing the bearings in the transmission is a false economy. Using incorrect or cheapo bearings would be downright foolish. Since I'm going to have the whole thing apart (and there is a little grease leaking out from under the brake cover) I'm going to replace the bull pinion shaft bearings at the same time.
What do you think ?
Greg
What do you think ?
Greg
