spraying poison hemlock
glennster
i got over run this year with poison hemlock. spot sprayed last year and thought i got it all. well, it came back with a vengeance. sprayed tri mec 2
weeks ago when we had a 70 degrees day. no effect on it. it seemed to enjoy it. tri mec has 2-4d, dicamba and mecoprop. i will post a pictue in a
minute
hemlock
At this stage of growth, Grazon Next is the only thing we have found effective. 2-4D works well until the plant is about 6 inches high.
duh, last year i used roundup on it. this year was tri mec spot sprayed, 4 ounces to the gallon.
The rest aren't suffering either. TRI MEC classic is a lot more potent than the regular. Give it a shot of Crossbow.It stinks a little more but does a good job.
I had never seen poison Hemlock until 2018. I was spraying my burndown mixture on a field for soybeans and saw this weed about three feet tall and almost that far across, thought what the H...! It wasn't there two weeks before, as I had a tree down in the field that needed cut up not 20 feet from where this weed stood. I wasn't sure what it was but I figured the glyphosate/ 2,4-D ester(lv4) mix should turn it to toast, so I soaked it good, slowed up and went back and forth over it a couple times till the spray was dripping off it everywhere. By the time I left the 11ac. field (it was on the first pass) it was already wilting, by time I planted the field there was no sign of it, not even a stem left. Did get a picture of it for identification so I could quiz the extension people about it, just can't find the picture now, must still only be on my phone not in the computer yet.
Poison Hemlock is a Biannual.
If you get at it before it gets out of control it can be controlled by simply cutting down the seed stalks (before they seed out) with a hoe for two or three consecutive years.
I've eradicated several patches this way.
Dean
Let the plant grow and flower. As soon as the flowers appear cut it down with a machete and dispose of the plant. This uses the root reserves so it will not resprout and gets rid of the plant before it goes to seed. You may have to do this for 2 or 3 years to get rid of all the seeds in your ground.
It is a pain to kill. Grazon next will do it but has residual. Crossbow too, but need to get it early. Don't let it go to seed, because it re-sprouts every year. Nasty stuff and poison to livestock after spraying and in wilted phase.
