starter button on Ford 600
Brian Joiner
My tractor wouldn't start. I changed the starter button on the transmission housing and it still wouldn't start or engage. I took the wire leading to the button and went direct to hot side of solenoid and she fires right off. Any ideas? Thanks, Brian
You have the wrong solenoid...
You need a solenoid that is activated by a ground 'signal' rather than a hot wire.
You might find that solenoid locally at NAPA or the like, but you're more likely to get the right one from a NewHolland dealer.
Rod
Solenoid on the 600 requires a hot wire from the ign. switch on one small terminal and a wire from the starter button on the other which supplies ground and engages the solenoid.
