Hey all-
I've got a gas Case 300 tractor and I'm in need of a starter. I'd consider a rebuild kit, however I've already replaced the brushes which didn't cure the intermittent no turn over from my existing starter. Worse, the spring loaded gearset (starter drive) has a pair of washers that retain the spring and slide up and down. Both have failed at the weakest point. I've gotten creative with the welder more than a few times to get it rolling again, so realistically it's time to get a new/rebuilt/used unit.
I've done the normal googling for it. However, all I can find are very pricy ($350-800) replacements.
The existing one is an Autolite MZ 4176. I've found several cross numbers in the archives, most notably the following:
USA 5453
MZ4180
Does anyone have a used unit? I could probably make one good one out of two, so even if yours is not 100%, I'd consider it.
Also, going over the available parts through this site, I can't seem to find any valve guides/seals listed. I've diagnosed the tractor to needing seals. I don't want to do a complete tear down/rebuilt right now and would rather get it's oil consumption down from a quart every few hours of use. Although the bugs don't seem to bother me, the blue smoke in my eyes prevents me from seeing the bucket at times.....
Anyone have any leads on these? Do they come in the head gasket kit?
USA 5453
MZ4180
