I replaced my LS k-5055 starter,the battery is new and 850 cca’s.problem is very slow cranking.I disconnected all lines to and from the front gear driven hydraulic pump.still the same.I bought this tractor used and it always was a little slow cranking but it’s getting worse.there’s only the clutch and transmission idler gears being turned while cranking now.i will try to temporarily over adjust the second stage clutch to be sure it absolutely disengages.while depressing the clutch.if that doesn’t work idk what it could be.this engine has no decompression lever.it does have an external by-pass valve that screws into the block I assume for the oil by-pass.any ideas.I’m not a mechanic but have been dealing with all kinds of farm/industrial equipment for a long time and have never had this problem
