Ol 54'
Not really sure, but appears to me that some water is finding its way into the transmission. I had checked the level about a month ago and it was barely trickling out of the right rear plug hole. Well now a couple of days ago it rained about an inch or so. Curiously I rechecked the level of the gear oil and I had about an extra quart coming out of it, the tractor has been in the same place for about 3 months now. I have 2 brand new Micron air breathers installed on it with a little bit of RTV. spread over the bolts. The gear shift knob has RTV on it also. All the bolts are tight holding the trans. cover down.. Would it be possible the water is finding its way past the bolts into the trans.. I don't know, I thought about RTV. the bolt heads????
