Super A is running again.
reidoinmo
I had the problem with the starter not cranking, replaced the saddle switch. Nothing still. Had it apart a few times. and still could'nt get it to work. The final try I cleaned all mating surfaces with my Die grinder and wire wheel. I found a small piece of gasket material on the starter under the saddle switch?
Anyway, put it back together testing at every step and it started! My conclusion is these 6V systems like good grounds!
Thank you
