Hey Everyone,
While I wait on machine shop to install new valve guides, valves and springs, etc. in my head, I am going to go ahead and install new head studs in my block. In the process of removing all the old pistons and sleeves I stripped all of them so they have to be replaced. 3 questions;
1) is there loctite or some other epoxy type cement that folks recommend placing on the threads when installing the studs into the block?
2) I am planning to thread 2 of the nuts onto each stud in order to tighten them down. I assume this is the best way to install the studs?
3) for the life of me I can?t find a spec for how far to drive the studs down? Maybe I am overthinking this, but I assume there is a correct and incorrect height they should sit when screwed down into the block?
Any insight would be highly appreciated!
Thanks,
Ben
Thanks,
Ben
