Super C waterpump
The bearings have gone bad and it makes a lot of noise, but it is not leaking. Got a 355760R93 from Amazon and it would not fit. Pulley was to far from face of block and lower bolt was metric. Anyone had this problem? Not sure were to order one from? Anyone got one from this site? Could I get a kit to repair this one? Thanks
(quoted from post at 09:34:16 10/16/22) The bearings have gone bad and it makes a lot of noise, but it is not leaking. Got a 355760R93 from Amazon and it would not fit. Pulley was to far from face of block and lower bolt was metric. Anyone had this problem? Not sure were to order one from? Anyone got one from this site? Could I get a kit to repair this one? Thanks
Looks like CIH still has the bearing, seal, and impeller available.
If you can press it apart without breaking the casting you could repair yours.
On the other hand, carefully press the pulley onto the bearing a bit more and grab a metric bolt and you should be able to use the aftermarket unit you already have.
