Texasmark1
Thinking about converting to a different "tool" for heating household water, 2 occupants.
Currently running a conventional 30 gallon, 30kBTU Propane burner, 3 ? OD double wall vertical, roof exhaust vent pipe, 75' ⅝ copper tubing to the tank/regulator, Fisher controls R632-JFF 750,000 BTU/Hr. rated regulator, 0.4 psi, 7/32" orifice.
Dishwasher, gas range and maybe 40kBTU of space heaters in the winter plus 2 bathrooms, also pulling on the 75' (from source) distribution point. A second line from the regulator same pipe, 120' long to a gas clothes dryer.....obviously everything won't be running simultaneously, maybe half or less usually.
Rating on the new tankless heater is 140k BTU/Hr for up to 6.8 gpm flow. Vent outlet is 4 ?" diameter and seems to be flanged so that my vent pipe will sit on it comfortably.........length about 10'.....problem carrying fumes from a 140k burner vs the 30k burner on a regular water heater?
For you users or knowers, am I opening a can of worms? If you just want to wash your hands at the sink, maybe using a quart or so of hot water, does it have to turn and off. Mfgr. didn't specify the size of the SS tank. Said it would last a lifetime....beats my 6 year average with current heaters on my high Alkaline (butttt soooo soft) water.
