This should make quite a difference
flying belgian
New lug tires mounted backwards on the 800 swather.
See if this works. Lately I've been having trouble posting pictures
i am just wondering why backwards? versatile 103 and hesston swathers used those tires and they were mounted correctly. it was the same set up with double tires.
As we discussed before, your only hope with swather is to back out. And quite frankly there's very little hope of that too. Soon as you realize it's a little soft, it's usually to late.
Dad always said... " The 4wd trucks just get a bit further from the house before getting stuck." and it was true of our hunters...
They are nice and should be of some help. I wouldn't be too confident tho as I have similar tires on my case and I rarely get to back out. The problem is they float so well you are in too far before you realize it. Hopefully it will be worth the cost.
that is very true , it will not happen. once in you will not back out, you will be getting the tractor to pull u backwards.
