Three point hitch sway chains
marvintj
I have a Mitsubishi/Satoh S470D that needs some help keeping the three point straight and not off to one side. I assume that on most three points there are chains or something that keeps the three point arms from flopping back and forth. My three point does not. What is standard for most tractors and does anyone know what the Satoh Mitsubishi S470D Should have?
Most have a chain on each side from some point near the back of the 3 point arm, forward to a point under the rear axle. This point needs to be in line with the front attachment point of the 3 point arm, so it doesn't bind when you raise or lower the 3 point. It's best if the chain has a turnbuckle in the middle, so you can loosen or tighten as needed.
I don't know what the Satohs had.
